[Gdal-dev] gdal ngpython win32
Didrik Pinte dpinte at itae.be
Thu May 11 09:31:54 EDT 2006
Le jeudi 11 mai 2006 à 13:58 +0200, Didrik Pinte a écrit :
> It fails because the linker cannot find gdal_i.lib.
I've hardcoded the path to gdal_i.lib in the swig/python/setup.py file
in order to try the swig interface.
It then builds correctly but the gdalnumeric.cpp file is not compiled.
How does the swig module have to be installed ? Without gdalnumeric, it
cannot work. I suppose that the old version is not the right one. Is
there something missing. I've tried it under linux, it seems to be the
same.
Any guidance is welcome ;-)
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060511/60ce125d/attachment.bin
