[Gdal-dev] Projection-Problem
Thu May 11 14:01:18 EDT 2006
Stephan Holl wrote:
> Hello Frank,
> thanks for looking into this.
> On Wed, 10 May 2006 11:14:40 -0400 Frank Warmerdam
> <warmerdam at pobox.com> wrote:
>> Stephan Holl wrote:
>>> PROJCS["GK Zone 4 (DHDN)",
>>>     GEOGCS[,
>>>         DATUM[,
>>>             SPHEROID["Bessel
>>> 1841",6377397.155,299.1528128],582.000000,105.000000,414.000000,-1.040000,-0.350000,3.080000,8.300000],
>>> PRIMEM["Greenwich",0.000000], UNIT["Decimal
>>> Degree",0.01745329251994330]], PROJECTION["Transverse Mercator"],
>>>     PARAMETER["Scale_Factor",1.000000],
>>>     PARAMETER["Central_Meridian",12.000000],
>>>     PARAMETER["False_Easting",4500000.000000],
>>>     UNIT["Meter",1.000000000000],
>>>     AUTHORITY["Oracle","82032"]]
Stephan,
As someone else noted, the PROJECTION name is the main problem
interfering with use.  I have submitted this problem in bugzilla
and hopefully we will address it.
   http://bugzilla.remotesensing.org/show_bug.cgi?id=1183
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
