[Gdal-dev] unable to load proj.4
EllenD ellen.debeuckeleer at incgeo.be
Thu May 18 05:07:22 EDT 2006
I retrieved a proj.dll from http://proj.maptools.org/ and the errors are
gone. I am a bit worried though, because I get the following georeference
information:
PROJCS["unnamed",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-117],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32611"]]
and this is what I expected:
"PROJCS[\"WGS 84 / UTM zone 11N\",GEOGCS[\"WGS
84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
84\",6378137,298.2572235629972,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4326\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",-117],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AUTHORITY[\"EPSG\",\"32611\"]]"
Might this be an inconsistency between the proj.dll and the GDAL version I
am using? And if so, where can I download the corresponding proj.dll? I am
using GDAL 1.3.1
Thanks,
Ellen
View this message in context: http://www.nabble.com/unable-to-load-proj.4-t1635846.html#a4446821
Sent from the GDAL - Dev forum at Nabble.com.
