[Gdal-dev] file size balloons when converting gml to tab, shp with ogr2ogr
Thu May 18 10:30:16 EDT 2006
Peter.Rushforth at statcan.ca wrote:
> Hi,
> I've been experimenting with converting GML documents to mapinfo tab and
> esri shp
> formats.  I have the same files previously created with commercial
> software with
> exactly the same record layouts.  The files I've created with ogr2ogr
> seem to be up
> to 5 to 10 times larger than the same file (and format) created with the
> commercial software.
> When you view the files, they appear identical, line for line, attribute
> for attribute.
> Is there somebody who could point me in the right direction to determine
> why?
Peter,
Generally speaking string fields without a defined size will end up being
very wide when translated to shapefiles since it is necessary for me to
pick a string width when creating the shapefile, but without prescanning all
the actual values that will be written.  This may also be an issue with tab
format, I'm not sure.  I don't *think* it is an issue with .mid/.mif.
So, is it primarily the .dbf file that is big for shapefiles?  The .shp
should generally be slightly more compact than the corresponding GML
geometry format.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
