[Gdal-dev] ogrinfo: Unable to initialize ODBC connection
Thu May 18 14:50:09 EDT 2006
Christian Wilmes wrote:
> Hi All,
> I try to connect to a PostgreSQL-Database over ODBC. When typing the command ogrinfo ODBC.ovf I get the following errors:
> ERROR 4: Update access not supported for VRT datasources.
Christian,
The above can be disregarded.
> ERROR 1: Unable to initialize ODBC connection to DSN for user/pass at Postgre,
> Specified driver could not be laodet due to system error 182 (PostgreSQL+).
The second line of the above sounds like a message from the ODBC system, not
OGR and presumably represents some real problem initializing the postgres
ODBC driver.  I don't see any problem with the ovf file itself.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
