[Gdal-dev] convert a GeoTIFF file into TIF + TFW files using gdal_translate ?
skotea at gmail.com skotea at gmail.com
Fri May 19 03:57:14 EDT 2006
Hi people !
Is there a way to convert a GeoTIFF file into TIF + TFW files using
gdal_translate ?
I'm able to get a TFW file from the GeoTIFF but I don't succeed in
converting my GeoTIFF file into a simple TIF file (with no coordinate data
in).
To make an automation of the process a command line is need (instead of
using a standard image processing software).
Thanks in advance people.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060519/2089af61/attachment.html
