[Gdal-dev] Inserting RPC data into an image?
Sarah Mulholland mulholland at nemesis.tucson.saic.com
Thu May 11 11:35:03 EDT 2006
I have a NITF image and RPC data in an external
file.  I'd like to embed the RPC data in the NITF
file.  I see there's a GDALExtractRPCInfo function
in gdal.  Would it be straightforward to create a
similar GDALInsertRPCInfo function?
Here's what I want to do:
	- read the image (or the header),
	- fill a GDALRPCInfo object with the right values,
	- insert the RPC object into the image (gdal data
set),
	- write it out with a new name.
Is this straightforward to do?
Thank in advance.
Sarah
