[Gdal-dev] ESRI Personal GeoDatabase driver
Mateusz Loskot mateusz at loskot.net
Mon May 22 13:58:56 EDT 2006
Schmoll,Martin [Edm] wrote:
> I’m new to MapServer, and am trying to use it with data in the ESRI
> Personal Geodatabase format.  I’ve installed ms4w 1.5.1., which includes
> GDAL\OGR 1.3.1.
> Apparently the ESRI Personal GeoDatabase format should be supported:
> http://ogr.maptools.org/ogr_formats.html
> When I run the ogrinfo utility on the .mdb file, I get:
> FAILURE:
> Unable to open datasource with the following drivers.
> A list of drivers is then displayed, which does not include ESRI
> Personal Geodatabase.
> How do I get/use that driver?
Is PGeo driver listed after you run:
ogrinfo --formats?
>From your explanation above, I understand it's not.
I'm not sure but most likely this PGeo driver is not built into GDAL
shipped with MS4W.
I have never used MS4W, so I'm not sure.
AFAIK, MS4W in version >= 1.5.3 includes PGeo driver (see MapServer
lists archives):
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05658.html
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
