[Gdal-dev] installing gdal
Christine Spietz
spietz at fh-bingen.de
Tue May 23 04:48:36 EDT 2006
Hi folks,
tried some other things to install the gdal/ogr-sources but they all don't
succeed.
Can please give anybody some help?
I think I may have located the error but I'm not sure and if it really is
the error other people should had have similar problems...... but I was not
able to find something on the list:
After all problems (see previous message) I decided that I must have choosen
the wrong configuration.
So I tried several kinds of (in my opinion) possible configurations. Last
one was
gdal-home >
./configure --with-jpeg=/usr/lib/gdal/gdal-cvs-2006.05.18/frmts/jpeg/libjpeg
(but I'm still not sure is it is the write path and I think I do not really
need to have a configuration with jpeg, because I "only" want to
transform/convert vector data)
The error-message after a 'make'-command was
>......../i586-suse-linux/bin/ld: cannot find -l jpeg
>collect2: ld returned exit status make[1]: ***[libgdal.la] Error 1
>make [1]: Leaving directory '/usr/lib/gdal/gdal-cvs-2006.05.18'
>make: *** [check-lib] Error 2
Now I thought maybe something wrong in the libgdal.la-file
(/usr/lib/gdal/gdal-cvs-2006.05.18/libgdal.la)
and in the file there it stands:
>#Libraries that this one depends on:
>dependency_libs='...... /usr/lib/libjpeg.la -lrt -ldl
>/usr/lib/libstdc++.la'
But I have no file libjpeg.la!
So again I configured:
./configure --with-jpeg=no, hoping the dependency-libs-list in libgdal.la
would change but it doesn't
after a make becoming the same error as I got before while trying to
configure without jpeg.
>/usr/bin/sed: can't read /usr/lib/libjepg.la: No such file or directory
>libtool: link: '/usr/lib/libjpeg.la' is not a valid libtool archive
>make[1]: *** [libgdal.la] Error 1
By the side it seems curious that by configuring with "--with-jpeg=no" there
is still the error message like this
I would be really gratefull for any help!
Christine
> Hi all,
> originally I wanted to use the java-swig bindings (and I still want to)
> but also after lots of help from the list (thanks to Ben and Frank) I was
> not able to install.
> So we decided that it might be the best to start the installation right
> new at the beginning. But I still can't do it. Here the things I did and
> what happened:
> a.. Download daily snapshoot: http://dl.maptools.org/dl/gdal/daily/:
> gdal-cvs-2006.05.18.tar.gz
> b.. unzip/tar in the gdal-home-directory (=GDAL_HOME) =>
> /usr/lib/gdal/gdal-cvs-2006.05.09
> c.. in GDAL_HOME/swig/java/java.opt JAVA_HOME set right
> d.. GDAL_HOME> ./configure (=> z.b. Eine Datei GDAL.opt aus GDAL.opt.in)
> e.. GDAL_HOME> make
> #####################error-log
> g++ .... .libs/ogrgeometryfactory.o
> In file included from ogrgeometryfactory.cpp:127:
> ogr_geos.h:47:22:error:geos_c.h: No such file or directory
> ogrgeometryfactory.cpp: In static member function static
> OGRGeometry*OgrGeometryFactory:createFromGeos(GEOSGeom_t*):
> ogrgeometryfactory.cpp:839: error:GEOSGeomToWKB_buf was not declared in
> this scope
> make[1]: ***[ ogrgeometryfactory .o] Error 1
> make[1]: Leaving directory '/usr/lib/gdal/gdal-cvs-2006.05.18/ogr'
> make: ***[ogr-target] Error 2
> a.. GDAL_HOME> ./configure -help =>
> a.. GDAL_HOME> ./configure --with-geos=yes
> b.. GDAL_HOME> make
> /usr/bin/sed: can't read /usr/lib/libjpg.la: No such file or directory
> libtool: link: '/usr/lib/libjpg.la' is not a valid libtool archive
> make[1]: Leaving directory '/usr/lib/gdal/gdal-cvs-2006.05.18'
> a.. GDAL_HOME> ./configure --with-geos=yes --with-jpeg=no
> b.. GDAL_HOME> make
> a.. GDAL_HOME> ./configure --with-geos=yes --with-jpeg=internal
> b.. GDAL_HOME> make
> Getting the same error as before ;-(
> Any idea what I am doing wrong?
> Best regards
> Christine
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
