[Gdal-dev] can not perform "gdal_merge.py", "gdal_rgb2pct.py" and "pct2rgb.py"
Zhonghai Wang zhonghaiw at gmail.com
Tue May 23 11:13:20 EDT 2006
Hi folks,
thanks for your information, I've installed Python on ma WIN XP system, and
now the .py commands do work well. Here is common info for others:
-- DO NOT install the latest version of Python, this will cause a version
conflict error; the version Python-2.3.5 is compatible with Python23.DLL in
MapServer.
I am using the MS4W 4.8.1 version.
thanks a lot.
zhonghai
On 5/23/06, Mateusz Loskot <mateusz at loskot.net> wrote:
> Zhonghai Wang wrote:
> > Hi guys,
> > to solve my last problem I am trying to merge all the GIFs into one
> > large TIF file usding the command gdal_merge.py, but the error
> > message says that no such a command can be found, [...]
> Do you use Unix/Linux?
> Have you built GDAL from sources or installed form packages?
> I use Ubuntu 5.10 (Debian) and gdal_merge.py script is available from
> package 'python-gdal'.
> What do you get from:
> $ which gdal_merge.py
> or
> $ locate gdal_merge.py
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060523/78e63f17/attachment.html
