[Gdal-dev] can not perform "gdal_merge.py", "gdal_rgb2pct.py" and "pct2rgb.py"
Zhonghai Wang zhonghaiw at gmail.com
Tue May 23 11:34:40 EDT 2006
Hi All,
I can only perform the gdal_merge.py command in FWTools shell. Why does it
still not work in DOS shell under MS4W? It gives still the same error
message: command can not be found. how can I make this also work under MS4W?
thanks
zhonghai
On 5/23/06, Zhonghai Wang <zhonghaiw at gmail.com> wrote:
>  Hi folks,
> thanks for your information, I've installed Python on ma WIN XP system,
> and now the .py commands do work well. Here is common info for others:
> -- DO NOT install the latest version of Python, this will cause a version
> conflict error; the version Python-2.3.5 is compatible with Python23.DLLin MapServer.
> I am using the MS4W 4.8.1 version.
> thanks a lot.
> zhonghai
>  On 5/23/06, Mateusz Loskot <mateusz at loskot.net> wrote:
> > Zhonghai Wang wrote:
> > > Hi guys,
> > > to solve my last problem I am trying to merge all the GIFs into one
> > > large TIF file usding the command gdal_merge.py, but the error
> > > message says that no such a command can be found, [...]
> > Do you use Unix/Linux?
> > Have you built GDAL from sources or installed form packages?
> > I use Ubuntu 5.10 (Debian) and gdal_merge.py script is available from
> > package 'python-gdal'.
> > What do you get from:
> > $ which gdal_merge.py
> > or
> > $ locate gdal_merge.py
> > Cheers
> > Mateusz Łoskot
> > http://mateusz.loskot.net
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060523/e0a57dc2/attachment.html
