[Gdal-dev] installing gdal
Christine Spietz spietz at fh-bingen.de
Tue May 23 11:37:35 EDT 2006
Hi Mateuz,
yes I tried (wrote it in my first message) but this also doesn't help.
First things I've tried can be found at the start of the thread
(http://lists.maptools.org/pipermail/gdal-dev/2006-May/008925.html) and
after nobody of the list had any ideas or hadn't the time to respond  I
tried several other things (described in the last message
http://lists.maptools.org/pipermail/gdal-dev/2006-May/008975.html) but they
also didn't succeed.
Have you any other idea?
Christine
----- Original Message -----
To: <gdal-dev at lists.maptools.org>
Sent: Tuesday, May 23, 2006 4:53 PM
Subject: Re: [Gdal-dev] installing gdal
> Christine Spietz wrote:
>> After all problems (see previous message) I decided that I must have
>> choosen the wrong configuration.
>> So I tried several kinds of (in my opinion) possible configurations.
>> Last one was
>> gdal-home > ./configure
>> --with-jpeg=/usr/lib/gdal/gdal-cvs-2006.05.18/frmts/jpeg/libjpeg
> Have you tried to use internal GDAL's JPEG library?
> Try to specify it as follows:
> --with-jpeg=internal
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
