[Gdal-dev] installing gdal
Patton, Eric epatton at nrcan.gc.ca
Wed May 24 08:50:04 EDT 2006
Correction; I've got every libstdc++ dev package installed!
~ Eric.
-----Original Message-----
To: 'Christine Spietz '
Cc: 'gdal-dev at lists.maptools.org '
Sent: 5/24/2006 8:44 AM
Subject: RE: [Gdal-dev] installing gdal
Interesting, Christine, I'm getting complaints from make about
libstdc++.la
not being a valid libtool archive, but I've got every dev package I
could
find in Ubuntu Synaptic installed, so I'm not sure what else I need.
~ Eric.
To: Christine Spietz
Cc: gdal-dev at lists.maptools.org
Sent: 5/24/2006 8:16 AM
Subject: Re: [Gdal-dev] installing gdal
Me again,
so finally I did it:
My steps for installing gdal:
1) download gdal1.3.2.tar.gz
2) unzip/untar at /usr/lib/gdal => /usr/lib/gdal/gdal-1.3.2 = GDAL-Home
3) ./configure
4) make
error messages like
>/usr/bin/sed: can't read /usr/lib/libjpg.la: No such file or directory
>libtool: link: '/usr/lib/libjpg.la' is not a valid libtool archive
>make[1]: *** [libgdal.la] Error 1
make sense if you know what actually they mean... (Thanks to Nicol!)
I had to install the missing packages
- libjpeg-devel and
- libpng-devel
curious:
even as I configures --with_jpeg=no I got the error that libjpg.la is
not
fount. So it seems taht these two packages are needed anyway to install
gdal
regards,
Christine
----- Original Message -----
To: "Mateusz Loskot" <mateusz at loskot.net>
Cc: <gdal-dev at lists.maptools.org>
Sent: Tuesday, May 23, 2006 5:54 PM
> Hi Mateuz,
> yes thats it: I'm trying now to build GDAL.
> I wanted to build Java and SWIG but then I realized that I had
problems
> with it because I actually was not able to build GDAL correctly.
> And there I'm :  no GDAL installed and therefore no chance to do
anything
> with gdal/ogr.
> Christine
> From: "Mateusz Loskot" <mateusz at loskot.net>
> To: <gdal-dev at lists.maptools.org>
> Sent: Tuesday, May 23, 2006 5:41 PM
>> Christine Spietz wrote:
>>> Hi Mateuz,
>>> yes I tried (wrote it in my first message) but this also doesn't
help.
>>> First things I've tried can be found at the start of the thread
>>> (http://lists.maptools.org/pipermail/gdal-dev/2006-May/008925.html)
and
>>> after nobody of the list had any ideas or hadn't the time to respond
I
>>> tried several other things (described in the last message
>>> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008975.html)
but
>>> they also didn't succeed.
>> Unfortunately, I'm completely not an expert of Java + SWIG
>> but I'd suggest you to try to build GDAL without any Java related
>> options first and see if it works.
>> Cheers
>> Mateusz Loskot
>> http://mateusz.loskot.net
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
