[Gdal-dev] Google Earth Data retrieval
Christopher Condit condit at sdsc.edu
Thu May 25 12:45:15 EDT 2006
If you've built MapServer as a WMS server then it's a simple piece of JavaScript to get your MapServer imagery onto GoogleMaps - wouldn't have to change anything in terms of your application and still have access to the Google imagery...
-Chris
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Nikolai Vladychevski
Sent: Thursday, May 25, 2006 9:01 AM
To: Ben Discoe; gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] Google Earth Data retrieval
> That said, much like other copyrighted media, if you
> are using the extracted
> images strictly for private, unpublished,
> noncommercial uses, you probably
> won't get prosecuted.  It's still technically
> illegal, of course.  Perhaps
> you could share what use you had in mind for the
> 'retrieved' images.
I know about Copyright Ben. That's exactly our case. I
work in a mobile phone company and we use MapServer to
display our network. Sometimes, the planning engineers
want to see  where is the antennas are located, and
satelite image is so good for this. I could integrate
my application with Google Earth probably, but I
thought maybe somebody had managed to retrieve the
images so I could integrate easily into my app. We
will be using it for private use, just like we can use
now Google Earth as standalone application.
Regards
___________________________________________________________
Do You Yahoo!?
La mejor conexión a Internet y <b >2GB</b> extra a tu correo por $100 al mes. http://net.yahoo.com.mx
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
