[Gdal-dev] OGRTINDEX support for Geodatabases?
Mateusz Loskot mateusz at loskot.net
Wed May 31 13:24:31 EDT 2006
Matt Wilkie wrote:
>> The other alternative is to build a DOS for loop to invoke
>> ogrtindex for each file via looping.
> e.g. for /r Z:\geodatabase %f in (*.mdb) do ogrtindex mdb_index.shp
> "%f"
> Will recursively search Z:\Geodatabase and index all .mdb files.
> Doesn't work on my machine though. Or rather the recursion works but
> ogrtindex exits with an error: "Schema of attributes of subsequent
> layers does not match ... Terminating."
And that's a correct behaviour of ogrtindex.
Please, see my previous post (second part) in this thread
or refer to Bug 1144:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1144
Simply, all layers processing with ogrtindex should have the same
attributes schema.
May be for PGeo this behaviour should be quite different, specific.
Frank, what do you think?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
