[Gdal-dev] Python/OGR SHAPE creation: prj file missing
Matthew Perry perrygeo at gmail.com
Wed May 31 16:20:50 EDT 2006
Markus,
  I usually cheat and just copy and existing .prj from a dataset with
the same projection. But it can be accomplished other ways as well.
If it's just an EPSG code, there the epsg_tr.py utility:
  epsg_tr.py -wkt 4326 > ${shapefile_prefix}.prj
Or if you want to do it within a python script:
srs = osr.SpatialReference()
srs.ImportFromProj4(.....)
## Or for EPSG codes
srs.ImportFromEPSG(int(....))
prj = srs.ExportToWkt()
## write the prj string to the appropriate file
- Matt
On 5/31/06, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> I was writing a simple Python script to generate a
> SHAPE file following
>  http://www.perrygeo.net/wordpress/?p=4
> (thanks, Perry!).
> The SHAPE related files are created, but the .prj file not.
> How to enable that?
> thanks
>  Markus
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Matt Perry
