[Gdal-dev] projection info in mapinfo tab files corrupt when specifying -a_srs or -s_srs and -t_srs in ogr2ogr
Daniel Morissette dmorissette at mapgears.com
Wed May 31 22:42:14 EDT 2006
This may be related to a bug in the MITAB library which is used by OGR
to read/write TAB files:
http://bugzilla.maptools.org/show_bug.cgi?id=1319#c7
See also:
http://bugzilla.maptools.org/show_bug.cgi?id=1254
Perhaps try rebuilding gdal/ogr/ogrsf_frmts/mitab with
-DMITAB_AFFINE_PARAMS (and then relink ogr2ogr) and see if the crash
goes away.
Daniel
Peter Rushforth wrote:
> Hi,
> I've done a little more testing and have a little more info.  I attach
> a csv file
> which demonstrates when the corruption of the tab file occurs.
> It appears to occur whenever the -a_srs option is used in ogr2ogr,
> or when the data is reprojected using -s_srs and -t_srs.
> The symptoms include crashing and irregular behaviour of mapinfo.  When one
> views the Change Current view dialog, the coordinates are garbage and
> the map units are incorrect.
> I am using fwtools 1.01 on windows, which *believe* is pretty up to
> date wrt cvs snapshots.
> I've been looking at the data files in mapinfo pro viewer 8.0 and tatuk
> viewer.
> Tatuk doesn't seem to notice the problem, mapinfo doesn't like it.
> Does this info lead anyone to conclude anything about possible causes?
> Cheers,
> Peter
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Daniel Morissette
http://www.mapgears.com/
