[Gdal-dev] C# Bindings
Simon Perkins sy at perkins.net
Thu Nov 2 00:58:13 EST 2006
I've just tried to use the GDAL C# SWIG bindings on Windows for the
first time today and ran into a couple of problems. I'm using Visual
Studio 2005 Express with SWIG 1.3.29.
I compiled GDAL and then typed:
 > cd swig\csharp
 > nmake /f makefile.vc interface
 > nmake /f makefile.vc test
The first two makes seem to work OK. The final test throws an exception
and prints the following:
Unhandled Exception: System.TypeInitializationException: The type
initializer fo
r 'OGR.ogr' threw an exception. ---> System.TypeInitializationException:
The typ
e initializer for 'OGR.ogrPINVOKE' threw an exception. --->
ationException: The type initializer for 'SWIGExceptionHelper' threw an
exceptio
n. ---> System.DllNotFoundException: Unable to load DLL 'gdal_ogr_wrap':
The spe
cified module could not be found. (Exception from HRESULT: 0x8007007E)
As with so many VS 2005 problems, this turned out to be a manifest
issue. Inserting a few lines into the makefile.vc to embed the manifest
files into the DLLs fixed this. I'll check in these changes if nobody
objects. I suspect that similar lines need to be added for other SWIG
languages on windows if anyone else feels like doing that...
However, I'm still a little unclear about exactly how to use the SWIG
libraries. My primary interest is in the GDAL RasterIO functions, which
seem to be present as Band.ReadRaster() and Band.WriteRaster(). The C#
function signatures for these are:
public int ReadRaster(int xoff, int yoff, int xsize, int ysize,
SWIGTYPE_p_int buf_xsize, SWIGTYPE_p_int buf_ysize, SWIGTYPE_p_int buf_type)
public int WriteRaster(int xoff, int yoff, int xsize, int ysize, int
buf_len, SWIGTYPE_p_int buf_xsize, SWIGTYPE_p_int buf_ysize,
These functions seem to be missing some arguments. In particular, how do
you pass in the buffer where data is to be read from / written to? What
are those SWIGTYPE_P_int types? Can anyone give me an example of how to
use these functions? Do they work? If not can anyone give me some
pointers on fixing them?
Cheers,
Sy
