[Gdal-dev] RFC 7: API Change for the VSIxxxL family of file functions
Thu Nov 2 10:52:32 EST 2006
Eric Dönges wrote:
> Am 01.11.2006 um 23:47 schrieb Ray Gardener:
>> fprintf can be handled with:
>>     int our_fprintf(our_file_t stream, const char* pszFormat, ...)
>>         va_list argList;
>>         va_start(argList, pszFormat);
>>         int n;
>>         if(stream.small())
>>             n = vfprintf(stream.filep, pszFormat, argList);
>>         else
>>             char sz[max_printf_len + 1]; // todo: unsafe
>>             n = vsprintf(sz, pszFormat, argList);
>>             large_file_write(stream.file, sz, n);
>>         va_end(argList);
>>         return n;
> While this approach would certainly work, I think it would be better to
> take an
> existing printf implementation (for instance from Cygnus newlib, located at
> http://sources.redhat.com/newlib) and adapt that to be exactly what GDAL
> requires.
> This would avoid the fixed length temporary buffer (which is ugly !) and
> allow us
> to have a locale-independent printf. I have adapted newlib's sprintf to
> print directly
> into a ringbuffer (and removed floating point to conserve space for an
> embedded
> project) before, so I know this is doable with moderate effort.
> IMO, the best way to do this would be to add an fgetc-like function to
> VSIVirtualHandle,
> and have a custom fprintf function that calls this fputc-like function
> for every
> character to output.
Folks,
I would point out there is no need for any big complexity in this regard.
It is perfectly possible to implement printf style functionality on any
system with vsnprintf().  The CPLString::Printf() function demonstrates this.
Basically use vsnprintf(), and if the working buffer is too small, reset and
try again with a bigger buffer.
The discussions of a scanf() replacement are more significant.
I'd add there may still be a number of drivers that directly use a variety
of stdio functions with the FILE *'s returned by VSIFOpen().  A careful
review of existing usage would be required before it could be determined
whether this is still a problem, or if it will be hard to rectify.
I personally would feel much more comfortable to *not* try and change the
non-L VSI API, and stay focused on the VSI*L api.  It might be desirable
to review if some use of the small api can be replaced with the large but
this seems mostly orthagonal to the main discussion.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
