[Gdal-dev] GDAL and Python
Christopher Barker Chris.Barker at noaa.gov
Thu Nov 2 16:45:08 EST 2006
Howard Butler wrote:
> At 02:08 PM 11/2/2006, Christopher Barker wrote:
> Is the "array interface" something that's hoped to be in Python proper
> in the near to distant future?  I'm not aware of what this is...
The array interface is an interface for describing arrays in memory that
you might want to efficiently pass around between different libraries.
It was developed and implemented in numpy, and back-ported to Numeric
and numarray:
http://numpy.scipy.org/array_interface.shtml
There is discussion right now on python-dev about including something
like it in a future python standard library.
Until then, the most recent version of PIL supports it, and I hope to
write some code for wxPython soon.
Is the plan for GDAL to depend on numpy? If so, then methods that return
  batches of data can return numpy arrays, which conform to the array
interface, and could be used by other libs that understand that, so it's
no big deal.
On the other hand, if numpy is optional, it would be nice if those same
methods would return an object that conforms to the array interface.
They could conform to the standard lib buffer interface at the same
time, I think.
Similar thinking for methods that take data as input.
> Arranging things into a "package" is something I've wished for GDAL for
> quite a while.
It really needs to be done!
> The problem is that there are an unknown number of
> legacy things out there dependent on gdal.py and ogr.py and the way they
> import. Re-arranging the deck chairs at this point could cause a lot of
> misery.
Aren't there going to be API changes anyway? editing import statements
is a very minor task.
> I don't know how we approach this other than to write and RFC,
> pass it, and just do it.
Nor do I. I say if you're writing the code, you have a lot of freedom to
  structure it the way you want.
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT         (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
