[Gdal-dev] gdalwarp to merge several images
Nicolas Ribot nicky666 at gmail.com
Fri Nov 3 12:09:31 EST 2006
Hello,
Refering to my previous post concerning gdal_merge.py, I now try to
use gdalwarp to warp several input images to produce one target image.
This target image is only a subset (a crop) of the the input images.
I noticed that when I call gdalwarp with several files, it reprojects
all of them even if they don't overlap (after transformation) the
target file bbox, leading to a very slow command when input files are
big (1 Go each).
In my script, I wrote a test to exclude from input images all the
images that don't intersect my target image (after having transformed
bbox in the same system)
Is there a way to do it automatically with gdalwarp ?
Thanx
Nicolas
(by the way, Franck, I did not find the post about gdalwarp and
merging in lists archives)
