[Gdal-dev] Error compiling gdal-1.3.2: libstdc++.la not found
Patton, Eric epatton at nrcan.gc.ca
Fri Nov 3 14:58:39 EST 2006
Thanks, Mateusz, that was exactly what was wrong!
Regards,
~ Eric.
-----Original Message-----
To: gdal-dev at lists.maptools.org
Sent: 11/3/2006 11:35 AM
Subject: Re: [Gdal-dev] Error compiling gdal-1.3.2: libstdc++.la not found
Patton, Eric wrote:
> Any ideas on how to get around this error?
Eric,
You've likely not installed all required development packages.
Install this one and try again
 http://packages.ubuntu.com/dapper/libdevel/libstdc++6-dbg
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
