[Gdal-dev] C# Bindings
Simon Perkins sy at perkins.net
Sun Nov 5 13:52:52 EST 2006
Simon Perkins wrote:
> OK, I see how this would work now. As you might guess, I still don't
> like the extra copying just to use a typesafe version of the method
> and to avoid the /UNSAFE keyword, but that's a personal preference. As
> long as the high performance IntPtr version of Read/WriteRaster() is
> available, I'll be happy...
Just to play devil's advocate a little, I'm going to point out that the
extra cost involved with allocating an intermediate buffer and copying
data for the typesafe versions of Read/WriteRaster() might actually not
be that significant...
 GDAL already does some intermediate copying of data since internally it
reads blocks of data, stores those in a cache, and then copies from
there to the user's buffer. In addition, if the block data has to be
fetched from disk, the cost of the disk I/O is certain to dwarf the cost
of a few extra memory copies...
Cheers!
Sy
