[Gdal-dev] gdal_merge.py resample method
guillaume huby guillaume.huby.lists at gmail.com
Mon Nov 6 05:08:26 EST 2006
Hello,
I'm using FWTools 1.6.0
I wondered about resample method used in gdal_merge.py when different
resolution are in inputs images.
In the script I found the following documentation :
"However,
        if the destination file is a different resolution, or different
        image pixel type, the appropriate resampling and conversions will
        be done (using normal GDAL promotion/demotion rules)."
Is the rule nearest neighbour, bilinear or some other resample method ?
Thanks in advance for replies.
Best regards,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061106/6eeb6a8e/attachment.html
