[Gdal-dev] ogr2ogr generate SQL sintax error
Richard Rossel henhiskan at gmail.com
Mon Nov 6 06:20:37 EST 2006
Ok thanks, I will report this bug.
BTW, what I am trying to do is to create a new shapefile from another
one, i.e., I must add, erase, rename fields from current shapeifle and
save it into new one . I wanted to do with Postgres, but  I have had
many problems with this. The question is: Can do that by another way?
Thanks a lot.-
On 11/6/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Richard Rossel wrote:
> > Hi list, am newbie here and I bring a big problem with me :(
> > I try to convert my shapefile into Postgres with ogr2ogr:
> > ogr2ogr -select "ID,FRC,FOW" -where "FEATTYP = '4110' AND ROUTENUM !=
> > ''" -f "PostgreSQL" PG:"host=localhost user=atlas dbname=atlas"
> > cheche________nw.shp
> > ERROR 1: INSERT command for new feature failed.
> > ERROR:  syntax error at or near "INTO" at character 83
> > Command: INSERT INTO "cheche________nw" (WKB_GEOMETRY , "id", "frc",
> > "fow") VALUES (INSERT INTO "cheche________nw" (WKB_GEOMETRY , "id",
> > "frc", "fow") VALUES
> > ('\\001\\002\\000\\000\\000\\003\\000\\000\\0000|3\\0401\\300\\041@\\205\\204\\336\\321\\265\\026G@\\374\\264\\212\\376\\320\\300\\041@\\304D\\336\\315\\256\\026G@\\024\\031\\014d,\\301\\041@\\242\\250}\\204\\253\\026G@',
> > 17561001781772, 4, 3)
> > ERROR 1: Terminating translation prematurely after failed
> > translation of layer cheche________nw
> > I found that the problem is that ogr write "INSERT INTO" twice times.
> > I take that sentence, drop the exra "INSERT INTO" and charge into DB
> > without problem.
> > How can fix it, and populate my DB with shapefile date.
> Richard,
> This sounds like an ugly bug in the postgis driver, but I'm pretty
> surprised.  Could you submit a detailed bug report via bugzilla with
> information on the GDAL/OGR version you are using, data files and
> the command?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Richard Rossel
Software Enginneer, WOS
Valparaiso - Chile
