[Gdal-dev] gdal install errors
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Thu Nov 9 09:57:58 EST 2006
Hello,
I tried on a fresh debian testing system to install the official gdal 1.3.2
source code and the cvs code (today), both resulted in the error messages
below when executing make.
Any hint, how to fix it is appreciated.
regards, Martin
./configure --with-grass=/usr/local/grass-6.3.cvs/
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /usr/local
  C compiler:                gcc -O2
  C++ compiler:              g++ -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  GRASS support:             grass57+
  CFITSIO support:           no
  PCRaster support:          internal
  NETCDF support:            no
  LIBPNG support:            internal
  LIBTIFF support:           internal
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              no
  HDF5 support:              no
  KAKADU support:            no
  JASPER support:            no
  ECW support:               no
  MrSID support:             no
  CURL support (wcs):        no
  POSTGRESQL support:        yes
  MySQL support:             no
  XERCES support:            no
  ODBC support:              no
  PGEO support:              no
  OCI support:               no
  SDE support:               no
  DODS support:              no
  SQLite support:            no
  DWGdirect support          no
  PANORAMA GIS support:      no
  GEOS support:
  Statically link PROJ.4:    no
  Traditional Python:        yes
  NG SWIG Bindings:
  enable OGR building:       yes
#make
make[2]: Nothing to be done for `install-obj'.
make[2]: Leaving directory
`/home/baliola/software/gdal_cvs/gdal/frmts/pcraster'
make -C grass install-obj
make[2]: Entering directory `/home/baliola/software/gdal_cvs/gdal/frmts/grass'
/bin/sh /home/baliola/software/gdal_cvs/gdal/libtool --mode=compile
g++ -Wall  -O2   -I/usr/local/grass-6.3.cvs//include -I/home/baliola/software/gdal_cvs/gdal/port -I/home/baliola/software/gdal_cvs/gdal/gcore -I/home/baliola/software/gdal_cvs/gdal/alg -I/home/baliola/software/gdal_cvs/gdal/ogr -I/home/baliola/software/gdal_cvs/gdal/ogr/ogrsf_frmts -DOGR_ENABLED -I/home/baliola/software/gdal_cvs/gdal/port  -c -o ../o/grass57dataset.o
grass57dataset.cpp
grass57dataset.cpp  -fPIC -DPIC -o ../o/.libs/grass57dataset.o
grass57dataset.cpp: In static member function 'static GDALDataset*
GRASSDataset::Open(GDALOpenInfo*)':
grass57dataset.cpp:948: error: 'GPJ_grass_to_wkt' was not declared in this
scope
make[2]: *** [../o/grass57dataset.o] Error 1
make[2]: Leaving directory `/home/baliola/software/gdal_cvs/gdal/frmts/grass'
make[1]: *** [grass-install-obj] Error 2
make[1]: Leaving directory `/home/baliola/software/gdal_cvs/gdal/frmts'
make: *** [frmts-target] Error 2
