[Gdal-dev] Performance on using Oracle Client XE
Wong Taka taka_www at yahoo.com.hk
Tue Nov 7 08:09:44 EST 2006
Dear All
  I am now studing a project about using mapserver to display map.
  In this map, points would be also shown. These points' XY and other info are stored in relational Oracle XE DB. For displaying, these point can be generated in acceptable time.
  However, when I retrieve the Points' attributes by grab the point in map. I found that the loading time is quite long. I have tried to add a index in Oracle XE for the XY in the table. It seems indifferent in performance.
  Are there any smart way to improve the performance? e.g. did fastCGI work? since I am using IIS to run Mapserver. I wonder.
  Thank you very much.
  by the way, I think this post should be post on MAPSERVER mail list, and I have tried also, but it always bound my post back. -_-"
  Regards
  Taka
 _______________________________________
 YM - Â÷½u°T®§
 ´Nºâ§A¨S¦³¤Wºô¡A§AªºªB¤Í¤´¥i¥H¯d¤U°T®§µ¹§A¡A·í§A¤Wºô®É´N¯à¥ß§Y¬Ý¨ì¡A¥ô¦ó»¡¸Ü³£ÉN¨«¥¢¡C
 http://messenger.yahoo.com.hk
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061107/8fc97507/attachment.html
