[Gdal-dev] Installation problems: GDAL 1.3.2 on Fedora5 (64Bit)
Thu Nov 9 22:47:51 EST 2006
Rainer Spittel wrote:
> Hi
>   Some weeks ago I tried to compile GDAL 1.3.2 on Fedora 5 32Bit and had
> some compiling errors. I got the advise to take the CVS version. That
> helped a lot and the compiling process went through without any problems.
>   Now I try to update the server, installing the same GDAL environment
> on a Fedora 5 64Bit OS and have compiling errors again. GDAL can not
> locate the libidn.so in /usr/lib. This library is in /usr/lib64.
>   What I tried if to copy the libidn.so file from the /usr/lib64 to the
> /usr/lib folder. It works - but I don't like it! ;-) This is a very
> scary approach to solve those problems.
Rainer,
If you can provide temporary ssh access to such a system, I could look
into the problem.  I am not aware of any problems on my 64bit ubuntu system.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
