[Gdal-dev] Create Images with GDAL in C#
Jean Michel PIERRET jmp at geosys.com
Mon Nov 13 14:15:06 EST 2006
I've just tried to use the GDAL C#, it's ok to read images,
But i have problem to create images, all my created images are empty.
public static void create(string file)
Driver dv;
      Dataset ds;
      Band ba;
      int bXSize, bYSize;
      int w, h;
      string [] options;
      w = 100;
      h = 100;
      bXSize = w;
      bYSize = 1;
      dv = gdal.GetDriverByName("GTiff");
      options = new string [] {"BLOCKXSIZE=" + bXSize, "BLOCKYSIZE=" +
bYSize};
      ds = dv.Create(file, w, h, 1, gdalconst.GDT_Float32, options);
      ba = ds.GetRasterBand(1);
      float [] buffer;
      buffer = new float [w * h];
      for (int i = 0; i < buffer.Length; i++)
            buffer[i] = i;
      b.WriteRaster(0, 0, w, h, buffer, w, h, 0, 0);
      b.FlushCache();
      d.FlushCache();
      b.Dispose();
      d.Dispose();
Thanks for your help and all your work on c# bindings.
PIERRET Jean michel.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061113/4589b000/attachment.html
