[Gdal-dev] gdalwarp - from Monte_Mario_Italy_1 to ETRF_1989_UTM_Zone_32N - offset ca. 120 m
Helmut Kudrnovsky hellik at web.de
Wed Nov 15 02:18:07 EST 2006
hi,
i have a tif-file with a world-file and warped the file with prj-files from arcgis for source and target.
-s_srs sourcep.prj
PROJCS["Monte_Mario_Italy_1",
GEOGCS["GCS_Monte_Mario",
DATUM["D_Monte_Mario",
SPHEROID["International_1924",6378388.0,297.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",-5000000.0],
PARAMETER["Central_Meridian",9.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
-t_srs targetp.prj
PROJCS["ETRF_1989_UTM_Zone_32N",
GEOGCS["GCS_ETRF_1989",
DATUM["D_ETRF_1989",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PARAMETER["False_Northing",0.0],
UNIT["Meter",1.0]]
i`ve looked into the warped tif-file. there is an offset of about 120 m in north-south-direction.
should i try gdalwarp maybe with the according epsg-code for source and target?
gdalwarp of fwtools 1.0.8 on win 2000-machine
with greetings from austria and thanks in advance
helli
______________________________________________________________________________
"Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's Cup-Yacht!
