[Gdal-dev] ODBC can't connect using SQL statement
Wed Nov 15 10:19:37 EST 2006
Eduardo Patto Kanegae wrote:
> Hi,
> I'm trying to access a point data table using MapServer through OGR VRT
> driver but I'm having errors.
> My data table is at SQL Server 2000 and I already created a system dns
> for this database.
> If I run:
> $ ogrinfo ODBC:myuser/mypassword at MYDSN -sql "SELECT * FROM PointTable
> WHERE themonth > 10"
> this works fine
> But when I try in MapServer:
> Then I got:
> msDrawMap(): Image handling error. Failed to draw layer named 'ptsodbc'.
> msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported on
> ExecuteSQL() results.
> msEvalContext: Expression parser error. Failed to parse context
> msyyparse(): Expression parser error. syntax error
> I only was able to filter data at this point table using FILTER and
> FILTERITEM keywords at mapfile, but only using regular expressions .
> Logical expressions does not show any point.
> Is that something wrong at my connection string or is this a bug to be
> solved using GDAL CVS ?
Eduardo,
In gda/ogr/ogrsf_frmts/odbc/ogrodbcselectlayer.cpp I see:
  * Revision 1.4  2006/05/15 18:14:31  fwarmerdam
  * Use generic mechanism for SetAttributeFilter() (bug 1185)
Unfortunately this was shortly after the GDAL 1.3.2 release.  So yes,
I believe you need to update to GDAL CVS (well a nightly snapshot is fine).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
