[Gdal-dev] OGR: VRT
Stephan Holl stephan.holl at intevation.de
Wed Nov 15 14:52:39 EST 2006
Hello Frank,
thanks for your fast reply.
On Wed, 15 Nov 2006 14:09:22 -0500 Frank Warmerdam
<warmerdam at pobox.com> wrote:
> Stephan Holl wrote:
> >   n2n_wert (Real) = 95.59999999999999   <--- strange, should be
> > 95.600 n2n_idflm (Integer) = 1207
> >   n2n_wertdat (String) = 2004-12-31
> >   n2n_idflaeche (String) = 04000000
> >   frmt_wert (String) = 95,600
> >   format_wert (String) = 95,600
> > Is this a known problem?
> > I am on Debian with gdal-1.2.6
> Stephan,
> I'd suggest trying again with the latest version (ie. a nightly cvs
> snapshot) and see if the problem persists.  There have been a lot of
> changes and improvements since 1.2.6.  If the problem persists you can
> file a bug report, hopefully with an sql script we can execute in
> mysql to initialize an example table showing the problem.
Thanks for the hint about the new changes. I backported my app since
1.3.2 does not work at all with vrt stuff in conjunction with MySQL.
So I decided to use 1.2.6 for this app. But I will give a nighly build
a shot and report back.
Best regards
	Stephan
Stephan Holl   : www.intevation.de/~stephan | GISpatcher:
www.gispatcher.de Intevation GmbH: www.intevation.de          | GAV
e.V.: www.grass-verein.de Georgstr.4     : 49074 Osnabrück            |
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061115/89c53ec0/signature.bin
