[Gdal-dev] C# Bindings Error
Tamas Szekeres szekerest at gmail.com
Wed Nov 15 16:04:11 EST 2006
I've just committed the changes for supporting the SWIG 1.3.30 C# builds.
Checkout and try the latest CVS.
Best Regards,
Tamas Szekeres
2006/11/15, Christian M. Gonzalez <cgonzalez at cepropa.com.ar>:
> Hello,
> I downloaded the cvs zip from 2006-11-14.
> I had success in building the gdal library, but when I tried to build the C#
> bindings, I got the following errors:
> --- BEGIN: COPY OF SCREEN ----------------------------
> C:\gdal\swig\csharp>nmake -f makefile.vc interface
> Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
> Copyright (C) Microsoft Corporation.  All rights reserved.
>         cd const
>         C:\swig\swigwin-1.3.30\swig.exe -csharp -namespace GDAL -dllimport
> gdal_gdalconst_wrap -o gdalconst_wrap.c ../../include/gdalconst.i
>         cd ..
>         cd gdal
>         C:\swig\swigwin-1.3.30\swig.exe -c++ -csharp -namespace GDAL
> -dllimport  gdal_gdal_wrap -I../../include/csharp -o gdal_wrap.cpp
> ../../include/gdal.i
> ..\..\include\MajorObject.i(54): Error: No methodmodifiers
> attribute defined in csdestruct typemap for MajorObject.
> ..\..\include\Driver.i(97): Error: No methodmodifiers attribute defined in
> csdestruct_derived typemap for Driver.
> ..\..\include\gdal.i(324): Error: No methodmodifiers attribute defined in
> csdestruct typemap for GCP.
> ..\..\include\Dataset.i(225): Error: No methodmodifiers attribute defined in
> csdestruct_derived typemap for Dataset.
> ../../include/csharp\gdal_csharp_extend.i(34): Error: No
> methodmodifiers attribute defined in csdestruct_derived typemap for Band.
> ..\..\include\ColorTable.i(57): Error: No methodmodifiers attribute defined
> in csdestruct typemap for ColorTable.
> NMAKE : fatal error U1077: 'C:\swig\swigwin-1.3.30\swig.exe' : return code
> '0x6'
> Stop.
> --- END: COPY OF SCREEN ----------------------------
> Could anyone tell me if I made a mistake in the process?
> Thanks a lot.
> Christian Gonzalez
> CEPROPA
> Patagonia – Argentina
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
