[Gdal-dev] gdal_translate: Floating point exception when trying to convert NSIF image (JPG)
Fri Nov 17 01:37:47 EST 2006
Reiner Beck wrote:
> Frank,
> the NITF image header says:
> - Rows (nrows): 749
> - Columns (ncols): 936
> - Actual Bits/Pixel: 8
> I will forward the image in a pm to you.
> Another NSIF/NITF related questions: are you aware of the BLOCKA geo
> extension? Are there plans to support it, as it is supposed to be more
> accurate than the IGEOLO?
Reiner,
I am only vaguely aware of it and hadn't had any plans to support it.
Georeferencing information is read from an RPF TRE in preference to
IGEOLO if available.   If I had a sample image, and a bug report it might
get implemented but it isn't clear to me how useful/important this would
be.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
