[Gdal-dev] *** glibc detected *** gdalinfo: free(): invalid pointer: 0x08053f7e ***
Reiner Beck R.Beck at m4com.de
Thu Nov 16 11:54:58 EST 2006
Frank,
sorry for bothering you again:
gdalinfo crashes badly on a different NITF/NSIF image. The image is not
compressed.
Oh, and the Geo Coordinates are wrong: the IGEOLO contains
'+41.284+020.075+41.319+020.078+41.317+020.126+41.282+020.123'.
Cheers
Reiner
> gdalinfo test.ntf
Driver: NITF/National Imagery Transmission Format
Size is 987, 1000
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (0.00000000,0.00000000)
Metadata:
  NITF_IC=NC
  NITF_IMODE=P
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000)
Lower Left  (   0.0000000,   0.0000000)
Upper Right (   0.0000000,   0.0000000)
Lower Right (   0.0000000,   0.0000000)
Center      (   0.0000000,   0.0000000)
Band 1 Block=987x1 Type=Byte, ColorInterp=Undefined
======= Backtrace: =========
/lib/libc.so.6[0xb7474911]
/lib/libc.so.6(__libc_free+0x84)[0xb7475f84]
/opt/m4com/util/lib/libgdal.so.1(VSIFree+0x21)[0xb7aecb51]
/opt/m4com/util/lib/libgdal.so.1(NITFImageDeaccess+0xa8)[0xb7a75918]
/opt/m4com/util/lib/libgdal.so.1(NITFClose+0x6f)[0xb7a70f4f]
/opt/m4com/util/lib/libgdal.so.1(_ZN11NITFDatasetD0Ev+0x5b)[0xb7a6d3db]
/opt/m4com/util/lib/libgdal.so.1(GDALClose+0x98)[0xb7ac5f78]
gdalinfo[0x804a835]
/lib/libc.so.6(__libc_start_main+0xdc)[0xb742687c]
gdalinfo[0x8049831]
