[Gdal-dev] Re: Problem : Building GDAL for windows CE
Mateusz Loskot
mateusz at loskot.net
Thu Nov 16 15:49:26 EST 2006
Today, I applied a few small fixes for Windows CE to the GDAL CVS.
I successfully compiled gdal for Pocket PC 2003 and Windows Mobile 5.0
using Visual C++ 2005.
Unfortunately, I don't have any free Windows box where I could
install eVC++ 4.0 at the moment.
That's all I can help for now.
Cheers
Mateusz
Mateusz Loskot wrote:
> kiruba,
> Please, give me a day till tomorrow night (Wednesday)
> I'm on my way to investigate it in details.
> I appologize to for the delay.
> Cheers
> Mateusz
> kiruba nantham wrote:
>> Hello Mr. Mateusz,
>> I am sorry to disturb you again and again, when you are busy.
>> Now I am building *gdal-cvs-2006.11.13 *I have copied all
>> the required headers and libraries to gdal-cvs-2006.11.13* *folder. Then
>> I started to build *gdal-cvs-2006.11.13 *from* *command prompt but now
>> it’s throwing this error *fatal error LNK1112: module machine type ‘X86’
>> conflicts with target machine type ‘ARM’*.
>> If I build *gdal-cvs-2006.11.13 (*evc4_gdalce_dll.vcw
>> workspace*)* using EVC++ 4.0. I am getting *gdalce_evc4.dll* but when I
>> am building *gdal-cvs-2006.11.13 *source I am getting 130 warnings
>> Warnings are:
>> Warning C4530: C++ exception handler used, but unwind semantics are not
>> enabled. Specify –GX.
>> Warning C4275: non dll-interface class 'std::basic_string<char,struct
>> std::char_traits<char>, class
>> std::allocator<char> >' used as
>> base for dll-interface class 'CPLString'.
>> These two warnings are repeating and
>> Linker Warnings are:
>> mitab_feature.obj: warning LNK1166: cannot adjust code at
>> offset=0x00001000, rva=0x0001C7DC.
>> mitab_feature_mif.obj: warning LNK1166: cannot adjust code at
>> offset=0x00001000, rva=0x000326C0
>> ogr_srs_proj4.obj: warning LNK1166: cannot adjust code at
>> offset=0x00001000, rva=0x000947D0
>> ogrspatialreference.obj: warning LNK1166: cannot adjust code at
>> offset=0x00001000, rva=0x000C5794
>> And also when it is connecting to emulator it’s prompting this
>> error (The intel 80486 CPU does not support configuration
>> evc4_gdalce_dll-Win32 (WCE ARMV4) Debug! Executable will not run on
>> device. Continue?) If I give OK to continue it is building this
>> *gdalce_evc4.dll *but it is of no use. Please can you tell me how to
>> solve this?
>> Thank you,
>> Kirubanantham.K.
>> Everyone is raving about the all-new Yahoo! Mail beta.
>> <http://us.rd.yahoo.com/evt=45083/*http://advision.webevents.yahoo.com/mailbeta>
Mateusz Loskot
http://mateusz.loskot.net
