[Gdal-dev] Gdalwarp resolution
Wed Nov 22 10:47:13 EST 2006
Sampson, David wrote:
> Hey folks,
> I am trying to move a 800 dpi to a 300 dpi image. The src image was
> created using gdal_translate to assign SRS, 4 GCP's and change from
> 16bit to 8bit image. Src image has the following meta_tags
> Metadata:
>   AREA_OR_POINT=Area
>   TIFFTAG_XRESOLUTION=800
>   TIFFTAG_YRESOLUTION=800
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>   Area_or_Point =Area
> The command line I am using is:
> gdalwarp -tr 300 300 oA38_001.tif S_A38_001.tif
> But I get this error
> Creating output file that is 0P x 0L.
> ERROR 1: Attempt to create 0x0x1 TIFF file, but width, height and bands
> must be positive.
Dave,
The "dpi printing resolution" information kept in some TIFF files is
completely disconnected from the georeferencing model of GDAL.  So
the -tr flag to gdalwarp is about setting the resolution in the
geo coordinate system of the image, but this image likely has none.
If you just want to downsample the image, you could try:
  gdal_translate -outsize 37.5% 37.5% in.tif out.tif
If you also want to override the resolution metadata tags (possibly
necessary to make printing software print properly) try:
  gdal_translate -outsize 37.5% 37.5% \
      -mo TIFFTAG_XRESOLUTION=300 -mo TIFFTAG_YRESOLUTION=300 \
      in.tif out.tif
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
