[Gdal-dev] Gdalwarp and memory optimization
Norman Vine nhv at cape.com
Fri Nov 24 05:41:59 EST 2006
Nicolas Ribot writes:
> Is there a way to tell gdalwarp to take more memory to work ?
> I see the -wo option, but can't find an option related to memory.
> In the GDAL warp api tutorial, there is a
> GDALWarpOptions::dfWarpMemoryLimit option.
> Can I use the same kind of option in the command line ?
http://www.gdal.org/gdalwarp.html
-wm memory_in_mb:
    Set the amount of memory (in megabytes) that the warp API is allowed to
use for caching.
HTH
Norman
