[Gdal-dev] ogr2ogr MapINfo bug?
Sat Nov 25 18:04:33 EST 2006
Mateusz Loskot wrote:
> Frank, I suppose the problem is that -sql query with asterix retrieves
> data as EWKB, because OGC functions AsBinary or AsText are not used,
> so PostGIS internal format is returned.
> Do you have similar considerations?
Mateusz,
I believe your analysis is correct.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
