[Gdal-dev] Re: your GDAL in C#
Tamas Szekeres szekerest at gmail.com
Sun Nov 26 06:17:39 EST 2006
The attachment you have referred is a separate project and I don't
know whether it was developed further or not. Maybe Simon Perkins
knows more about it.
However you can also use the GDAL C# SWIG interface contained by the
gdal project
and can be accessed from the CVS.
For more details about the CVS access see:
http://www.gdal.org/download.html
Best Regards,
Tamas Szekeres
2006/11/26, ÚO½¨Ã÷ <yunjm2005 at gmail.com>:
> Hi,Tamas
> I have read this mail today, and have download the GDAL_CSharp.zip C#
> bindings from
> http://article.gmane.org/gmane.comp.gis.gdal.devel/6177 .
> but it is posted"Date: 2006-01-09 02:33:03 GMT (45 weeks, 6 days and 56
> minutes ago)
> ".so i want to find the latest version, where can i find it.
> thinks your work!
>  ________________________________
> ÚO½¨Ã÷
> 2006-11-26
> ·¢¼þÈË£º Tamas Szekeres
> ·¢ËÍʱ¼ä£º 2006-11-19 04:32:51
> ÊÕ¼þÈË£º Simon Perkins
> ³­ËÍ£º gdal-dev at lists.maptools.org; MIKAH JAMES TRENT
> Ö÷Ì⣺ Re: [Gdal-dev] Re: your GDAL in C#
> It would be considerable to use the GDAL SWIG C#
> interface since it
> seems to be easier to support along with the evolution
> of the GDAL
> core. We are planning to expose most of the
> required functionality for
> the next release.
> However if you decide to use this interface feel free
> to share your
> experiences and help us to discover the missing
> but required
> functionalities and the possible problems. So as
> to collect these
> problems we have also created a bugzilla component
> dedicated
> exclusively to the C# interface.
> Best Regards,
> Tamas Szekeres
> 2006/11/17, Simon Perkins  <sy at perkins.net >:
> > It's been a while since I looked at that code -
> the standard thing to do
> > now is to migrate to using the SWIG generated C#
> bindings, though those
> > are far from complete.
> > OK, just looked at the code. GDALGetMetadaExt() is
> the declaration of
> > the external (to C#) native GDAL function
> GDALGetMetadata(), that uses
> > raw strings and pointers and so forth. However, to
> make the function
> > easier from C#, the C# GDALGetMetadata()
> function has an API that uses a
> > Dictionary object. The C# GDALGetMetadata()
> method simply calls
> > GDALGetMetadataExt() to do the work, which in turn
> calls the underlying
> > GDAL function.
> > If you're getting zeros, I would check that you can
> use GDAL withe the
> > C++ API first. Note that most file formats
> don't support metadata and
> > will silently return null pointers. The "domain"
> flag should generally
> > be null - it allows different metadata namespaces to be
> set up but I
> > don't think any formats support that.
> > BTW, the gdal-dev list is the place to ask
> questions like this. I've
> > copied the list with my answer, for the record.
> > Cheers,
> > Sy
> > MIKAH JAMES TRENT wrote:
> >  > Hi Simon,
> >  > I am working with the UW-Madison ecology labs as
> a student programmer.  I am trying to use
> your C# code that you posted on
> >  > to see if we can use or extend your C# wrapper
> to incorporate GDAL into our own projects
> (see http://www.landis.forest.wisc.edu).
> >  > Could you help me understand what the function
> "GDALGetMetadataExt" does, or maybe just
> point me to where it is defined??  The following
> line of code (from InterOp.cs, in your function
> GDALGetMetaData):
> >  > void** stringList = (void**)
> GDALGetMetadataExt(hDataset, domain);
> >  > always returns 0 for me, even when I am certain
> the dataset is not empty.  You also have
> 'domain' set to "null" (in Dataset.cs) when you call
> GDALGetMetaData.  Could this have
> something to do with it??
> >  > I'm a little new to the whole system, so any help
> you could provide, even if it's just
> pointing me somewhere, would be great.  Thanks
> a bunch,
> >  > -Mikah
> > Gdal-dev mailing list
> > Gdal-dev at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/gdal-dev
