[Gdal-dev] warping MODIS data with gdal
Markus Neteler neteler at itc.it
Wed Nov 29 04:49:11 EST 2006
On Wed, Nov 29, 2006 at 10:19:01AM +0100, guillaume huby wrote:
>  I found some dirty trick to tell GDAL about it, see my script at:
>  [1]http://mpa.itc.it/markus/useful/modis_hdf2erdas_ll_wgs84.sh
>    Dirty trick, but working trick ! I used the same commands on a MOD09GQK
>    product and get the same result than using MRT.
>    Thank you for this nice job.
>    Guillaume.
Glad to hear that!
Now we only have to figure out why we need the dirty trick.
See also related problem with MODIS LAI:
 http://bugzilla.remotesensing.org/show_bug.cgi?id=1239
(dirty trick also works with that)
cheers,
Markus
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
