[Gdal-dev] RFE 1369: reading gzipped files in situ (raster.tif.gz)
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Nov 29 12:59:30 EST 2006
Hello All, I've run into a fair amount of raster imagery, OnEarth for
example, which is available gzipped instead of using an internal
compression. It would be very convenient if gdal could read gzipped
files in situ. Having to decompress the files to a scratch space first
means having to keep a lot extra room around to manouver as well writing
a lot of little throughway scripts. In other applications which do read
.gz files such as VTP it also seems to be a lot faster to read/write a
.gz than an uncompressed file. Perhaps because of less disk use (?).
Request For Enhancement #1369
http://bugzilla.remotesensing.org/show_bug.cgi?id=1369
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
