[Gdal-dev] Virtual Spatial connection to PostgreSQL ODBC driver
Jeff McKenna jmckenna at dmsolutions.ca
Wed Nov 29 14:12:45 EST 2006
and all information_schema tables have proper column definitions, for
example:
   Table "information_schema.sql_sizing_profiles"
      Column     |      Type       | Modifiers
  sizing_id      | cardinal_number |
  sizing_name    | character_data  |
  profile_id     | character_data  |
  required_value | cardinal_number |
  comments       | character_data  |
jeff
Jeff McKenna wrote:
> I'm attempting to connect to X/Y data stored in a PostgreSQL table (no
> geometry) through OGR:ODBC, and getting the following errors:
> ogrinfo ODBC:@mydsn xxx -summary
> ERROR 1: No column definitions found for table 'sql_features', layer not
> usable.
> 'sql_implementation_info', layer
> not usable.
> ERROR 1: No column definitions found for table 'sql_languages', layer
> not usable
> ERROR 1: No column definitions found for table 'sql_packages', layer not
> usable.
> ERROR 1: No column definitions found for table 'sql_sizing', layer not
> usable.
> ERROR 1: No column definitions found for table 'sql_sizing_profiles',
> layer not
> usable.
> INFO: Open of `ODBC:@mydsn'
> using driver `ODBC' successful.
> Layer name: xxx
> Geometry: Unknown (any)
> Feature Count: 840
> Layer SRS WKT:
> (unknown)
> nf: Integer (10.0)
> pe: Integer (10.0)
> ns: Integer (10.0)
> nb: Integer (10.0)
> qc: Integer (10.0)
> on_: Integer (10.0)
> So for some reason the ODBC:OGR connection cannot find the
> information_schema tables, even though they exist, shown here in psql:
>                         List of relations
>        Schema       |          Name           | Type  |  Owner
>  information_schema | sql_features            | table | postgres
>  information_schema | sql_implementation_info | table | postgres
>  information_schema | sql_languages           | table | postgres
>  information_schema | sql_packages            | table | postgres
>  information_schema | sql_sizing              | table | postgres
>  information_schema | sql_sizing_profiles     | table | postgres
>  public             | xxx                     | table | postgres
> This becomes a show-stopper when trying to display the layer in MapServer:
>   msDrawMap(): Image handling error. Failed to draw layer named 'xxx'. <br>
> msOGRFileNextShape(): OGR error. No column definitions found for table
> 'sql_sizi
> ng_profiles', layer not usable. <br>
> These same errors occur with GDAL 1.3.2 and CVS-head.  I'm connecting as
> the postgres user, which owns the information_schema tables and my x/y
> table.
> Anyone see what I am doing wrong?
> thanks.
> jeff
