[Gdal-dev] gdal_merge.py Gtiff files with -pct losing color
Wed Nov 29 18:02:26 EST 2006
Izzy wrote:
> Hi,
> I am trying to compose a geotiff satellite image by stitching several
> satellite geotiff images.
> All of them are one band images with same pseudo color table.
> When merging the images with -pct to preserve the color table, I get a
> black image.  When I don't use this option, I get a fainted final
> picture since the color is now Grey Scale.
> I noticed that the pseudo color table for each of the input images look
> different if I use gdalinfo and ImageMagick command identify.
> I attached the gdalinfo and IM info files for one of the input
> images:AS_GMSNO_gdalinfo.dat and AS_GMSNO_IMinfo.dat and the gdalinfo of
> the output image obtained using gdal_merge.py  with and without "-pct"
> option(out-pct_gdalinfo.dat and out_gdalinfo.dat).
Izzy,
The gdalinfo report of the color table in AS_GMSNO_gdalinfo.dat is clearly
badly messed up.  Is this your input file?  Can you provide it to me for
closer inspection?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
