[Gdal-dev] easy way to create tile index of dted (dt0) files?
Fri Oct 6 10:20:27 EDT 2006
Holger Wilken wrote:
> I want to create a tile index of dted files (dt0) as a shapefile (shp), to show the boundaries of dted cells on my map.
> So far, I have succeeded in using the steps:
> - generate a file with all dt0 filenames (dir /b /s *.dt0 > all_dt0.txt)
> - use the DOS FOR command in combination with gdal_translate and the all_dt0.txt file to build a geotiff for each dt0 file
> - use gdaltindex on the resulting tif files to create a tile index.
> my question: is there another (faster) way to create the tile index directly out of the dt0 files, without the detour via tif?
> thanks in advance
Holger,
I'm not sure why you converted them to TIFF.  Gdaltindex will work fine
against .dt0 files.  As long as your gdaltindex is built with wildcard
support on windows (as the one in FWTools is for instance) you should
be able to just do something like:
  gdaltindex index.shp *.dt0
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
