[Gdal-dev] MrSID support kills gdal_translate?
Alan Stewart astewart at TerraGoTech.com
Tue Oct 10 11:47:02 EDT 2006
I figured it out. Gdal is configured by default to use the LizardTech
DLL rather than the static lib. The DLL needs to either be copied to the
same directory gdal is installed to or the path to the DLL needs to be
in the PATH environment variable. Or nmake.opt can be modified to link
to lti_dsdk.lib instead of lti_dsdk_dll.lib
Alan Stewart wrote:
> When I enable MrSID support in nmake.opt, the resulting gdal_translate
> seems non-functional. It simply returns with no output, no matter what
> the input is, including requesting the version with "--version". I
> don't see any errors in the output from nmake. Anyone have any idea on
> what could be wrong?
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
 Alan Stewart
 Senior Software Architect
 TerraGo Technologies, Inc.
 678-391-9700 x9615
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061010/dd6bd92e/astewart.vcf
