[Gdal-dev] ogr2ogr
GeoUser blazrepnik at mail386.com
Thu Oct 12 04:17:28 EDT 2006
thanks all!
well i followed the steps on the site. but (i guess i'm missing something)
the problem is still here. if i copy the correct dlls into correct dirs i
still can not execute:
ogr2ogr -update -append -f "OCI" "OCI:user/pass at host2" "OCI:user/pass at host1"
i still get:
FAILURE:
Unable to open datasource `OCI:user/pass at host1' with the following drivers.
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> AVCBin
  -> REC
  -> Memory
  -> CSV
  -> GML
  -> ODBC
  -> PGeo
  -> PostgreSQL
  -> MySQL
how do i use the OCI dll with ogr2ogr?
Jeff McKenna wrote:
> For the record here are the steps in the readme:
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g
> jeff
> Frank Warmerdam wrote:
>> GeoUser wrote:
>>> Thanks for the answer but i downloaded the MS4W but the OCI was not
>>> present
>>> in ogr2ogr...
>> Anonymous GeoUser,
>> I believe you need to copy C:\MS4W\gdalplugins\ignored\ogr_OCI.dll into
>> C:\MS4W\gdalplugins.
>> I think this is discussed in C:\MS4W\README_INSTALL.TXT in the section
>> about
>> Oracle 10g.
>> Best regards,
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/ogr2ogr-tf2380732.html#a6771753
Sent from the GDAL - Dev mailing list archive at Nabble.com.
