[Gdal-dev] OGR returns wrong floating values for shapefiles (and integer as real, in error)
Maciej Sieczka tutey at o2.pl
Tue Oct 24 04:40:18 EDT 2006
ogrinfo (and other apps based on OGR, eg. OpenEV, QGIS) returns wrong
floating point values querying my shapefiles. Eg.:
$ ogrinfo -al -q streams.shp
Layer name: streams
OGRFeature(streams):523
  CAT (Real) =         484
  LCAT (Real) =          73
  Z (Real) =      101.583309999999997
  Z_BREACH (Real) =      101.583309999999997
  Z_BREACH1 (Real) =      100.583309999999997
  LENGTH (Real) =        2.036246000000000
  LINESTRING (598549.144524969975464 5677309.376777020283043,598550.0
5677311.224603090435266)
After opening the dbf in oocalc 2.03, I can see the values should
recpectively be:
CAT	  484
LCAT	  73
Z	  101.58331
Z_BREACH  101.58331
Z_BREACH1 100.58331
LENGTH	  2.036246
Why the spurious "09999999997" in case of Z, Z_BREACH, Z_BREACH1 in
OGR? Note that, interestingly, LENGTH is OK though.
Morevover, CAT and LCAT are not Real numbers. They are integer. Why
reported as real?
Is any of the issues fixed in newer GDAL? I've been using 1.3.2 CVS
2006-07-24.
The shapefile is attached if needed.
Maciek
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061024/b98f1eb4/streams.tar.bin
