AW: [Gdal-dev] coordinates for csv-files with ogr2ogr
C.Strobl at dlr.de C.Strobl at dlr.de
Tue Oct 24 09:17:12 EDT 2006
hallo frank,
thanks for your fast answers. so the way to get ascii-coordinates with ogr is to export in gml or kml. or is there another possibility?
best regards
christian
> -----Ursprüngliche Nachricht-----
> Von: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Gesendet: Dienstag, 24. Oktober 2006 15:01
> An: Strobl, Christian
> Cc: gdal-dev at lists.maptools.org
> Betreff: Re: [Gdal-dev] coordinates for csv-files with ogr2ogr
> C.Strobl at dlr.de wrote:
> > hello all,
> > is there a possibility to generate with ogr2ogr a csv-file which
> > contains also the coordinates and not only the attributes.
> > thanks and greetings from munich.
> Christian,
> This is not possible with the current csv driver.  Geometries
> are always discarded.  In theory it would not be hard to
> modify it to allow geometries to be emitted as a WKT column,
> or perhaps for point data to be split into an X, Y (and Z) column.
> > christian
> > p.s. besides this ogr2ogr generates always with the csv-option a
> > folder AND a file with the same name, e.g. .../file.csv/file.csv
> Right - on creation the driver always creates a directory and
> creates each layer as a csv file inside that.  Some drivers,
> like the shapefile driver, have hacky logic to try and
> determine if a single shp/shx/dbf file set should be created
> or a whole directory.  But this is complex and problem prone
> and this capability was not replicated in the csv driver
> which is by design fairly simple.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo,
> http://osgeo.org
