[Gdal-dev] ERDAS IMG .aux file
Tue Oct 24 13:07:56 EDT 2006
flightline wrote:
> Dear Sir,
> Do you have hfatest.exe with you. May I request a copy?
> The .ovr file I have has an EHFA Header Tag
> and I can't figure it out.
> Unfortunately I can't send you a sample but have requested for another
> sample set.
> Any / all help with the tag and decoding it's contents is welcome
Francis,
It isn't terribly convenient to send you a hfatest executable.  Can you
download GDAL and build it?  If so, then you can cd into gdal/frmts/hfa
and specifically build hfatest.  On linux:
  make hfatest
on windows:
  nmake /f makefile.vc hfatest.exe
If this is impractical, I can build a hfatest.exe that should work with
the last FWTools build for windows.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
